Call of Duty 2
Publisher:
Activision
We used the full version of
Call of Duty 2, patched to version 1.2.  The game makes use of some awesome effects and is generally very graphically intense and immersive.  That's helped by the tremendous smoke effect that Infinity Ward has created -- it's better than anything we've ever seen before.  There are also real time shadows and subtle HDR lighting effects too.
The gameplay is not as linear as the first version of
Call of Duty, and Infinity Ward has ditched the rather old
Quake 3 engine in favour of creating its own proprietary graphics engine to render the effects.  There is something about the game that makes it very intense and you often find yourself having to take a break from the action because you're too overwhelmed by its immersiveness and intensity.
We used a custom timedemo that covers both indoor and outdoor performance in the title across one of the most intensive portions of the game.  The
Optimise for SLI option was disabled for single GPU configurations as it causes some texture corruption if there is only one GPU present.  It was enabled for dual-GPU configurations and all other options were set to their maximum values.
        Nvidia GeForce 8800 GTX 768MB SLI
        ATI Radeon X1950 XTX 512MB CrossFire
        BFGTech GeForce 8800 GTS OC 640MB SLI
        ATI Radeon HD 2900 XT 512MB CrossFire
        XFX GeForce 8800 Ultra 650M Extreme
        EVGA e-GeForce 8800 Ultra Superclocked 768MB
        Nvidia GeForce 8800 Ultra 768MB
        EVGA e-GeForce 8800 GTX KO Superclocked ACS³ 768MB
Frames Per Second
Frames Per Second
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
Frames Per Second
XFX's 8800 Ultra 650M Extreme manages to outperform the EVGA e-GeForce 8800 Ultra Superclocked by the slimmest of margins in
Call of Duty 2.  It looks like the slight core and shader clock speed differences aren't impacting performance and we're more memory bandwidth limited, as XFX's 650M Extreme has a tiny bit more memory bandwidth on tap.
